mount drag shocks upside down?
Old Mar 30, 2012 | 06:57 PM
slim84maro's Avatar
Car: 86 Camaro
Engine: 5.7 with some mods.
Transmission: 700r4 needs shift kit
Axle/Gears: Stock.
I heard it was better to mount your drag racing shocks upside down. Is this true?
Old Mar 30, 2012 | 07:08 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Re: mount drag shocks upside down?
Why would it matter? Seems like they'd work the same either way...
Old Mar 30, 2012 | 07:16 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Depends what you're trying to do. The valving is different on compression and rebound.
Old Mar 30, 2012 | 09:22 PM
Confuzed1's Avatar
Car: 83Z28 HO
Isn't "compression" when the rod goes in, and "rebound" as it extends? I thought it was the same even upside down?? -I don't think I'm missing anything.
Old Mar 31, 2012 | 07:45 AM
SCCAjunkie's Avatar
Car: 84 Z28
Engine: 91 L98 long block with Pro-jection
Axle/Gears: 91 10bolt w/ 3.42s and T2R
Confuzed- correct.
The reason for inverted shocks is to reduce the unsprung weight. This isn't just a "drag shock" thing. With the body of the shock mounted to the axle, you have to have all that mass moving with the axle as it moves. In theory, reducing that mass can make a difference.
I'm not sure of any other reason why you'd invert shocks, so if I'm missing something, let me know
Old Apr 3, 2012 | 09:27 PM
83 Crossfire TA's Avatar
SCCAjunkie is right WRT to what the advantage is, and it shouldn't change the dampening _as long as_ they work upside down. Some shock designs will, some will not. I would call the manufacturer and ask.
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
87camaro87
Sep 9, 2015 10:29 PM
FormulasOnly
Sep 6, 2015 10:42 AM
SG91camaro
Sep 5, 2015 10:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
