Opinion's/Suggestions needed
Old Apr 2, 2012 | 08:14 AM
Jaboski's Avatar
Car: 91 Firebird
Axle/Gears: 3.08
Just removed my r/f LCA do service my bushings/bj, and the hole for the end link is a little oblonged or ovaled out, whatever term you would like to use. Its about 1/4 of an inch more in diameter on its widest point versus the shortest. Is this a huge issue or should I replace them?
Old Apr 2, 2012 | 10:06 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Opinion's/Suggestions needed
Since the problem is common, finding a replacement might be hit and miss. I had mine repaired (a bit of welding, a bit of grinding) a few years ago. You might try the so-called 1LE endlinks as the heads are a rounded and may well Bandaid the issue.
http://www.top-downsolutions.com/cha...e-End-Link-Kit
JamesC
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
