Rear Axle Codes
Old Apr 6, 2012 | 03:36 PM
Wrench Bender's Avatar
Rear Axle Codes
Rear End Codes
I have 1984 Z28 and am trying to find out the gear ratio in it. I found the stamped code the axle housing... This where I need help. All the sights either don't go to 1984 or they don't have the right information. The code on the housing is 6HFC0892 or it is GHFC0892. Please can anyone help me?
Old Apr 6, 2012 | 03:57 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Rear Axle Codes
Originally Posted by Wrench Bender
Rear End Codes
Welcome to TGO, Wrench. Dropping the cover and checking the numbers on the ring and pinion (or counting teeth), as mentioned in post #1 of the link below, may be the best option for absolute verification:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Apr 7, 2012 | 10:41 AM
Re: Rear Axle Codes
Thanks for the info. Found what I was looking for.
Old Apr 7, 2012 | 11:25 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Rear Axle Codes
Probably a good idea to pull cover and clean inside and out new gasket and syn. gear oil.
hectre13
Dec 11, 2023 08:14 AM
customblackbird
Aug 15, 2021 10:16 PM
draco
Oct 4, 2015 09:25 PM
E Rod
Aug 28, 2015 05:17 AM
