Energy Supension 36mm sway bar bushing question
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Hey guys.
Can I re-use my stock sway bar bushing mounts for the 36mm sized bushings? Will they fit properly, or do I have to get new (taller) mounts from Energy?
I paid to have the stock mounts powdercoated and hope to re-use them.
Thanks to anyone who knows the answer.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Energy Supension 36mm sway bar bushing question
Hey guys.
JamesC
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
I thought Energy Suspension only made up to 34mm bushings. Did you find 36's that fit our cars?
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
Yeah the shells won't fit the ES 36mm bushings. The 34mm are the only ones that will fit, Lon from Top-Down solutions commented on this last week. He sells the 36mm bushings.
What he does, is buys the 34mm and turns the insides to 36mm with the proper tools.
Car: 1991 Camaro Z28
I just put the energy 36mm on a few weeks ago. They fit very snugly cuz the bolt is a little shorter than the stock one but I had to cut the spacer down a tiny bit on the passenger side one cuz the mount was positioned weird but made it fit without any other problems. You should be fine.
Notice that there's a bracket delete option, under bushing options, from Lon:
http://www.top-downsolutions.com/gre...amaro-or-fireb
JamesC
JamesC
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
