Lots of sway
Old Apr 25, 2012 | 04:08 PM
StringRust's Avatar
Car: '89 Camaro Rs/ '87 Z28
Engine: 305 c.i. TBI/ 305 c.i. 4bbl
Transmission: 700r4/T5
Axle/Gears: 3.73 posi/ 3.73 posi
Lots of sway
Just got my brothers 88camaro on the road today so I took it for a drive. Feels like a boat. Sways quite a bit when you turn the wheel back and forth.
Other that that it rides solid and smooth. Even though the sway bars and bushings/end links look decent should we try replacing them first to see if that eliminates the problem?
Old Apr 25, 2012 | 04:58 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
Re: Lots of sway
I have the same problem with mine currently.
I just ordered some intrax lowering springs, and a new panhard bar. Feels like mine moves side to side. Hoping the Panhard bar helps with that.
Check the panhard bar, the rear control arms, and all the bushings.
I can update you further after this weekend (hopefully)
Old Apr 25, 2012 | 05:50 PM
wretched737's Avatar
Re: Lots of sway
Depending on what was done to the car while it was off the road, make sure to check all bolts are tight, its an easy enough mistake to forget to tighten something all the way
Old Apr 26, 2012 | 07:11 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Lots of sway
You don't mention whether the struts/shocks have been replaced at some point. If not, they're well over 20 years old and no doubt require replacement. And, of course, all the rubber bushings are in the same boat.
JamesC
Old Apr 26, 2012 | 04:30 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: Lots of sway
JamesC
Beat me to it...
J-money
Jan 4, 2019 09:45 AM
camaro1185
Oct 26, 2015 06:51 AM
89-91fun
South West Region
Sep 12, 2015 03:06 PM
87camaro87
Sep 9, 2015 10:29 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
