lowering back of dragcar
Old Apr 30, 2012 | 09:52 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
Axle/Gears: moser 12 bolt spool 4.11
dropping down from my 295s to 275s want to close up the fender gap. whats the best way of dropping the back of the car and still making it hook? i hear things about people running different springs and weight jack but i know nothing about any of that. is that the way to go or is there another way? teach me...
Old Apr 30, 2012 | 10:50 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: lowering back of dragcar
I just change the coil over height position with the brackets on the diff to get the ride height I want.
You don't want the back of a production car down too far. It will really screw up your drivetrain geometry. Drag cars that look like they're sitting on the ground are tube chassis cars. The body sits low but the chassis is still high.
Old May 1, 2012 | 05:43 AM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
i dont want to slam the back of the car just close up the gap... probly drop and inch or so
Old May 1, 2012 | 07:39 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
if you still have the stock rubber insolator on top of the rear springs, you can take that out and it will net you maybe a half inch? if its not enough you can cut a little off the top of the springs to lower it a bit more.
Old May 1, 2012 | 08:04 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
can anyone tell me a little about different springs and the weight jacks? that seems like the better way to go.
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
