LOUD squeak from front left
Old May 7, 2012 | 04:27 PM
blue birdy 87's Avatar
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
Hey recently my car developed a minor squeak comming from what sounds like the front left tire. It made noise whenever you were moving and shut up from just lightly holding the brakes (not enough to start slowing the car). Now a couple of days have gone by and the noise is much louder, and only stops if your on the brakes like your going in for a stoplight
From using search bar it sounds like this should be wheel bearings or brake discs, but those posts had nothing about it stopping under braking.
Any ideas?
Old May 7, 2012 | 04:59 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: LOUD squeak from front left
Sounds like a wheel bearing to me.
Old May 7, 2012 | 07:03 PM
Brake pads
It's the "audible wear sensor"
Old May 7, 2012 | 07:36 PM
WolfmanTA's Avatar
Car: 1986 Trans Am
Engine: LB9 TPI V8
Transmission: automatic
Had the same problem need to apply some brake molly grease to the back of your pads. What it is doing the pads are moving around in the caliper. Try that. Cheers...
1992 Trans Am
May 10, 2023 07:19 PM
Andrew6.688
Dec 13, 2015 10:59 AM
xxx3man`
Sep 23, 2015 10:37 PM
bdads
Aug 24, 2015 06:01 PM
db057
Aug 22, 2015 08:17 PM
