S 10 manual steering box install help.
Old May 8, 2012 | 06:16 AM
crazypurgatory's Avatar
I finley found a S 10 manual steering box to put in my 1988 Firebird.
Which pitman arm do I use the s10 or the Firbird one?
Thanks,
Old May 8, 2012 | 07:08 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: S 10 manual steering box install help.
The third gen pitman arm would work best.
Old May 8, 2012 | 07:12 AM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
haha this cracks me up. i just sold an iroc steering gear box to a guy at work to put in his s10 because he couldnt stand the manual gear box looks like you 2 could have traded
Old May 8, 2012 | 08:28 AM
Tony V's Avatar
Car: 88 Camaro
Engine: 383
Axle/Gears: Moser 9 inch/4.11 TruTrac
Thanks,
If your S-10 steering box looks like this, the 3rd gen pitman will bolt right up.
If it looks like this, you'll need the s-10 one.
Old May 8, 2012 | 05:02 PM
Yea thats the one I have.
Thanks Guys I will use Pitman arm off the firebird.
Old May 8, 2012 | 09:03 PM
AlkyIROC's Avatar
Car: 87 IROC L98
The S10 pitman arm will work but it's a different length. It will change the steering geometry slightly. I think the main change will be the turning radius.
Trouble with keeping the S10 pitman arm is that the idler arm on the other side will be the wrong length. Again, it screws up steering geometry mostly in turns. For those of us who mainly do straight line acceleration with very little turns, the S10 pitman arm will do just fine. If you want to use it in a street car then the F-body pitman arm is highly recommended.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
backtothe80s
Sep 5, 2015 12:39 AM
red90IROCls1
Aug 25, 2015 06:56 AM
Bull86
Aug 10, 2015 05:43 PM
