what size is the column joint?
Old May 14, 2012 | 04:43 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
Axle/Gears: moser 12 bolt spool 4.11
switched over to a rack now i am making a steering shaft i need to know what size joint i need to adapt to the factory column. i believe it is 1"dd am i correct? input would be great. pics would be even better.
Old May 14, 2012 | 10:25 PM
rlewi771's Avatar
Car: 86 IROC
Engine: 350 ZZ4
Transmission: TKO-600
Re: what size is the column joint?
https://www.thirdgen.org/forums/susp...ing-shaft.html
Old May 18, 2012 | 11:00 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
that didnt really help me... im assuming by looking at the pics that the column joint is 1"dd?? i wouldnt use a 1"dd by 3/4"dd because im using 3/4" round moly tubing.... so i would need 1"dd by 3/4 smooth if this is correct
Thirdgen89GTA
Oct 19, 2015 09:27 AM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
bubbaz28
Sep 18, 2015 02:09 PM
Tweeks25
Sep 17, 2015 08:04 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
