Less harsh IROC ride?
Old May 19, 2012 | 08:48 AM
Mortorq's Avatar
Car: '88 IROC T5 Vert ‘13 Vette
Engine: 305 TBI
Axle/Gears: 3:08
2 schools of thought on handling I've found.
A) GM's Herb Adams thicker sway bars and softer springs, or,
B) Dick Guldstrand's no sway bars and very stiff springs.
Any of you pros ever change out IROC springs for RS springs, but keep the sway bars and IROC steering box for a slight improvement in bang-itself-to-pieces on rough roads harshness?
'88 IROC T5 vert LO3
Old May 21, 2012 | 10:23 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: Less harsh IROC ride?
Guldstrand did not advocate no sway bars, just heavier springs with stock bars (and poly hardware).
If you did not have sway bars, you would crash pretty much on the first drive.
Old May 21, 2012 | 10:33 AM
SCCAjunkie's Avatar
Car: 84 Z28
Engine: 91 L98 long block with Pro-jection
Axle/Gears: 91 10bolt w/ 3.42s and T2R
Not sure about that on an F-body, but my race car runs NO front swaybar, and only the factory rear "bar" (round stock welded to the trailing arms on a "live axle" setup). Now, it is front wheel drive, and I run 800 lb. front springs (on strut) with 550 lb. rears (coil-over shock) and it's only 2400 lb., but it's got crappy weight bias and many of the same shortcomings in the suspension department as these cars do.
Old May 22, 2012 | 08:55 PM
SlickTrackGod's Avatar
On Probation
Swaybars depend on the perticular vehicle roll dynamic (Basically talking about the vehicle suspension geometry design and the positive roll affect on the mount points.
Having once been a race car driver for Dick Guldstrand, his concept is more geared towards the C2 and C3 Corvettes. Most Vettes do not need a rear swaybar at all and the fronts are very small- unlike a third gen.
ANyways- either has nothing to do ith ride quality. Getting a balnce of spring rate from both spring and bar, or only bar is both the smae relitive harshness. What controls ride quality is sprung to unsprung weight. You want to add chassis weight, and reduce suspension and wheel assembly weight to increase ride quality. Thats why Cadillacs are so heavy for that "Cadillac ride"
Old May 22, 2012 | 09:00 PM
On Probation
Spring rate vs swaybar size has everything to do with the amount of braking and accelerating g's the car will experience- to go further it would have alot also to do with aero squat (does not pertain to street and freeway speeds- so forget this point) and also bank turn compression( again, not for street use so forget this point also).
The more you have to get on the brakes and distrubute weight over the front end under braking, and then assert weight over the rear tires for acceleration- the more you want heavier springs to control the chassis weight for and after. Lesser brake dive and acceration squat? then you can generally get away with lighter spring rates and a slightly heavier sway bar choices. (For sake of confusion- I am not going to get into shock dampering and how it affects spring rate choice)
Old May 22, 2012 | 09:40 PM
SCCAjunkie's Avatar
Car: 84 Z28
Yep, inertia at work. Keep the floating stuff floating (chassis) and make the moving stuff have little effect by low relative mass (wheel/hub assembly). Spring it with just enough rate to keep the chassis at ride height but still allow, what, 75% deflection travel at the high end of street encounters, and use *just enough* damping to keep the bounce under control, and all of a sudden, you have a Cadillac, or as many of us think of it, a wallowing lux-o-boat.
The light-spring-big-bar theory will lighten up the ride over two wheel bumps, but most road issues are asymmetrical, so the bar loads the wheel rate back in again if both wheels aren't affected equally. Unless you go with a truly sophisticated (read-active) handling system, good ride and decent "handling" are probably going to be mutually exclusive for the most part on these cars.
Old May 26, 2012 | 11:26 AM
On Probation
Hey, I drive a Lux-o boat everyday and resemble that remark
A 1985 suga caddy ed do rad do (laughing). Everyone laughs at my reputation and my confidence to drive such a piece of ****. (With the pink fuzzy dice hanging off the rear view mirror of course- gotta have that)
Old Jun 5, 2012 | 10:12 PM
grego93536's Avatar
Car: 91 rs3.1, 87 iroc 305 6 speed
Can anyone tell me the difference between iroc front control arms, and all other third gen arms? Any light shed on this will be appreciated. ( I know they are different between the 15 and 16 inch rimmed cars )
Old Jun 6, 2012 | 06:07 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
No real difference in the arm itself, but there are differences as seen below:
https://www.thirdgen.org/forums/susp...s-created.html
JamesC
Old Jun 6, 2012 | 08:39 AM
SCCAjunkie's Avatar
Car: 84 Z28
James, I have to say, I'm consistently impressed with how much info you have links to, or even have posted yourself. Every time I follow one of your links, I learn something.
If you want to mod the steering stops on stock 15" wheel a-arms to better limit things for 16" wheels, I've tacked on a piece of 5/16 rod (about 1 1/2" long, laying along the working edge of the stop) as a spacer to mimic the slightly longer stop. On that note, does anyone actually have the difference in length of the stops? I'd like to know how close I am...
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
88gta3508
Aug 29, 2015 08:25 PM
Linson
Aug 21, 2015 02:12 PM
mustangman65_79
Aug 11, 2015 03:17 PM
