Astro Van steering shaft bearing
Old May 22, 2012 | 01:48 PM
drumminfoolz's Avatar
Car: 1985 Trans Am
Engine: 360
I've had trouble with my original steering column, and at this point it's not worth trying to rebuild it. I found a guy with a 96 Camaro to sell me the steering column out of it. I have a 93 Jeep Cherokee that I will get the intermediate steering shaft from. As far as the bearing goes, I haven't been able to find a junkyard that has an Astro Van or one that is willing to sell me just the bearing. I have a bearing #FW184 from AC Delco but I don't know if this will work yet. I've seen it posted that #7805700 is the correct bearing, but some people said it didn't fit. Also, whenever I get the correct bearing, will it work with the cap/retainer on my Trans Am, or will I have to find one from an Astro Van?
Old May 22, 2012 | 02:39 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Astro Van steering shaft bearing
Astro vans are plentiful at the local pick and pulls, so I can't be helpful in that regard. Info on the cap and so forth below. Note that they aren't all the same:
https://www.thirdgen.org/forums/susp...g-bearing.html
Maybe something useful on the Jeep shaft below, if you haven't seen it:
https://www.thirdgen.org/forums/susp...ing-shaft.html
JamesC
Old May 23, 2012 | 09:25 PM
Car: 1985 Trans Am
Engine: 360
I got the new steering column put in today. The steering is a lot tighter and easier to turn now. I didn't need an Astro van bearing like I've seen posted before. The only parts I needed were the steering column and the intermediate shaft.
Old May 24, 2012 | 06:42 AM
JamesC's Avatar
No, you didn't need the Astro bearing, but it is an improvement over the OE plastic bushing.
JamesC
83 Crossfire TA
Jan 3, 2016 01:26 PM
dbrochard
Oct 3, 2015 12:43 PM
punkmaster98
Sep 8, 2015 09:45 PM
dbrochard
Sep 7, 2015 09:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
