lower control arm question
Old May 28, 2012 | 10:02 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
i have aftermarket lower control arms.... they dont have grease fitting... could i add grease fittings to them or no...
Old May 29, 2012 | 08:26 AM
UMI Sales's Avatar
Re: lower control arm question
It would depend on what type of bushings they have. Our bushings are a split type which allow a pathway from the outside to the flutes on the inside. It may be more tricky to get grease to flow properly with another bushing type.
ramey
Old May 29, 2012 | 06:01 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
yea, you need to take it apart and see how the bushing is made. you need a gap int eh center, where the grease fitting would go, and the bushings need flutes around the center sleave. You can add the flutes with a file if they are not there, not ideal, but it will work.
whos arms? if they are not grease able, that pretty shitty
1992rs/ss
Jan 31, 2025 05:10 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
redmaroz
Aug 16, 2015 11:40 PM
