stock sway bars or aftermarket?
Car: 87 Iroc-z
Engine: 383 TPI
Transmission: 700 R4
Axle/Gears: 3.27 posi
so i have an 87 iroc with 34mm sway bar on front, and looks like 22 or 23 on the rear. would it be better to keep these or buy aftermarket from spohn or bmr or whoever?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: stock sway bars or aftermarket?
Does the car need more or less bar? If it doesn't, no need to lighten the wallet. If you want to clean them up and give them a coat of paint, that will make them look much better.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I agree with 86.
Aside from his suggestion of paint, you might consider a powder coat.
JamesC
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Save your money.
I cleaned my 36/24 combo at the coin carwash and sprayed them with some Duplicolour red engine enamel rattle can I found on sale.
I did upgrade to poly bushings and ES end links.
Car: 1986 Z28
Engine: 305ci
WOW!! I did a search like most do not and found exactly what I wanted.
My 86 has original bars. I had the same question.
Sounds like unless there is a need, remove them clean and paint them and add new bushings. Thanks for saving me hundreds!!!!
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
