energy suspension sway bar end link kits???
Car: 1985 trans am
Engine: 355 vortec built 4 bolt main
Transmission: 700r4 w/ shift kit b&m console mega
Axle/Gears: 3.08
I have a 1985 pontiac trans am. I upgraded and put a 36mm front sway bar on it. I am wondering what the part number is for an energy suspension 36mm sway bar bushing and sway bar endlink kit for a 82-92 camaro/firebird 36mm bar. Help would be much appreciated thanks!
Re: energy suspension sway bar end link kits???
Don't know the part # offhand; but, ES measures their parts in inches, not mm. If memory serves they don't have a bushing that size, you have to take a slightly smaller one and hone it out. Finished size will be slightly greater than 1-3/8".
For the end link kits, you want ones that make the bar sit level when the car is at its normal rest position. For most of use that will mean about 2¾" end links.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The 36 mm bushings and end links can be found at the sites below:
http://www.spohn.net/shop/1982-1992-...s-Accessories/
http://www.top-downsolutions.com/chassis-and-suspension
JamesC
JamesC
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
