Lakewood Control arms w/ mini ladder bars?
Old Aug 6, 2012 | 09:36 PM
musicfreako's Avatar
Car: 89' camaro RS TTOP
Engine: 92 5.0tpi Bosch III, headers, msd
Transmission: 700r4 built. trans go. 2,300 stall
Axle/Gears: 3:73 posi ls disc brake conversion
Just scored a set of these rear control arms. They have they're own little bar connected to them that also attaches to the axle via its own little bracket? Kinda like a mini ladder bar. Are these junk/pointless. I can upload a picture later if no one knows what im talking about. Paid 60 bucks for them. They're the square tubing grease-able poly type bushing control arms. It looks like they would help prevent axle twist. Let me know if these are a decent set up. Thanks guys. Also scored a hotchkis adjustable pan hard for 40 bucks.
Old Aug 6, 2012 | 10:53 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Re: Lakewood Control arms w/ mini ladder bars?
Never heard of this before. Interested in photos.
Old Aug 7, 2012 | 10:22 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
They are junk. Scrap the brackets and other parts and keep the poly control arms by themselves. The idea behind the those lakewood parts is to eliminate the torque arm and gain traction. Problem is they are too small and the brackets are weak and wil fail.
Old Aug 7, 2012 | 12:15 PM
Here's a picture. I figured these would at least help the stock torque arm out. Not eliminate it.
Old Aug 7, 2012 | 12:41 PM
Mlanzo's Avatar
Car: 1985 iroc
Engine: 5.0
Transmission: auto
looks like some sort of LCA relocation bracket.
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
I got a set on my car and they work fine. However I did break one, just had it welded back where it cracked. I've broken quite a few things on my car with really hard launches (see sig)....nothing new there.
Definitely much better than the stock control arms. Keep em, I've been running mine for 10yrs now.
Old Aug 7, 2012 | 09:46 PM
Car: 1985 Z28
Interesting idea. But is this the same piece the OP posted a picture of? What he has almost looks like an LCA with a built-in LCARB.
Old Aug 7, 2012 | 10:09 PM
Car: 89 Formula
Engine: 383 SBC/HSR
Yes, they are the exact same part. If you aren't doing any 1.5 60ft launches, they'll work fine. They are called Lakewood Lift-Bars - designed to load the rear end and eliminate control arm flex.
Some love them.....some don't, it just depends on your intentions for the car.
Old Aug 7, 2012 | 10:27 PM
Car: 1985 Z28
Looks like quite an interesting piece, however the street is where my car lives 95% of It's life, and these look like they would KILL handling. Def a nice mod for a track car though. I'd run a set if I wasn't worried about the bendies.
Old Aug 8, 2012 | 06:41 AM
I don't see how the would kill handling. They are just preventing axle twist.
Old Aug 8, 2012 | 08:17 AM
Car: 1985 Z28
With LCARBS, if you adjust the angle of the LCA too far downward it will make the vehicle prone to oversteer when exiting a corner.
These look like they're basically doing the same thing.
Old Aug 8, 2012 | 08:25 AM
Car: 89 Formula
Engine: 383 SBC/HSR
Never had any over steer problems, it just prevents axle twist...like mentioned earlier. If you're looking into doing some serious cornering this isn't what you need. It enhances straight line performance.
I have an 9-bolt with an Australian full-spool so i take it easy in the corners.
Old Aug 8, 2012 | 08:26 AM
brando54009's Avatar
Car: 82 firebird
Engine: a few
Transmission: th350
Axle/Gears: wondering this myself
the stiffest end of the vehicle is almost always the one that will slide around. with that being said if you are caring about handling then i would probably look elsewhere for parts but personally i don't think i would do enough corner carving is a strait axle car to really care about it, more on the strait road type of guy with these cars, but to each his own i guess
Old Aug 8, 2012 | 09:38 AM
These arms don't change the angle of the rear control arms. They're just adding extra reinforcement. The beauty of these bars is that I can add or remove a little ladder bar depending on what type of driving I'm doing
Old Aug 8, 2012 | 09:46 AM
Car: 89 Formula
Engine: 383 SBC/HSR
Yep.....that's correct. Factory control arms will flex, these won't. Pretty simple.
Old Aug 11, 2012 | 03:10 AM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
on a side note:
the Lakewood parts you have there are never Intended to eliminate the torque, at any time!
ONLY to help pre load and tune Your factry Set Up
so anybody thats running THEM with out there TQ arm...give them a smack!
this also falls under, the goofballs who Run the south side Lift bars/ladder bars.
and remove the LCAs..LOL, THEY should read the how to install part, that comes with them!!
Old Aug 11, 2012 | 03:21 AM
<<guys who dont read!!
Old Aug 11, 2012 | 06:52 PM
Exactly. I wouldn't remove tq arm. Just the tuning capabilities are what interest me.
Old Aug 12, 2012 | 11:33 PM
they will help take, a bit of the slack, out of the stock set up
preloading the rear end/pinon angle up or down. to the way you like.
note: not to be set up like a dilivry Truck...lol!
lakewood adds (not intended for Drag Racing).
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
J-money
Jan 4, 2019 09:45 AM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
