Driver side lower after Sportline Spring install *PICTURES*
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
Alright folks,
So i had the mechanic throw in my front set of Eibach Sportline springs, 2 days ago.
I noticed from afar that the driver side is lower than the passenger side, and once I got the car back home on level pavement I noticed just how much of a difference there was.
Driver
Passenger
Any reasons why one side is higher than the other?
It makes me curious if the passenger side could have been slightly off when it was being indexed.. I haven't had a chance to talk with the mechanic just yet...
And I've read everywhere on here that springs don't settle, but rather the rest of the car settles around it... Any chance that could take place and even the sides out?
One last thought.... Is there any way shape or form that the front sway bar can have ANY effect on this? As in bushings, end links, anything at all??
Driver
Passenger
Car: 1991 RS/B4C clone
Engine: 355 TPI
Transmission: Probuilt Street/Strip 700r4
Axle/Gears: 7.625 axle with 3.23 gears/TrueTrac
Re: Driver side lower after Sportline Spring install *PICTURES*
They probably aren't indexed properly.
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
It will all need to be checked out.
or on the lower side your mechanic forgot to put the rubber isolator back in, maybe stuck to the old spring??
Engine: 454-350
Let us know what you find.
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
I'm going to go with the spring didn't go all the way in the pocket....
I had the same thing happen on my iroc...
Car: 1991 Z28 Vert
When you check, scrap the stock isolated and use some heater hose, just as good and easier to work with.
Car: 87' GTA
Engine: 350 L98 TPI
I'll let y'all know what comes from it, it might be a while before I can get this looked at but I'll try to make sure and post back. Thank y'all
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
