adjustable shocks??
Old Sep 22, 2012 | 09:57 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
adjustable shocks??
I'm looking for a shock/strut that I can adjust from say as stiff as stock but then my softer or launching that car from a stop. I read a little up on KYB AGXs but they seem to just go from as stiff as stock to stiffer. Any other setup other there that I can adjust easy? Competition C 2700??
Old Sep 23, 2012 | 07:24 AM
Re: adjustable shocks??
Sounds like your standards for "stiff" are pretty low, if "stock" seems "stiff" to you...
About the only way to get less "stiff" than "stock", is to take the shocks completely off.
What does the car do wrong, that you are thinking you can fix with shocks that aren't as "stiff" as "stock"?
Old Sep 23, 2012 | 10:39 AM
Car: 89 Formula 350
Well, I'm running KYB GR2s in the car now. KYB says they are 10-15% firmer then factory. The car handles well with them. What you didn't follow is I'm looking for something that I can adjust from a firm ride to a setup also I can adjust that will transfer weight for a drag launch. So what the car does wrong is melt my drag radials and not even think about hooking.
Old Sep 23, 2012 | 06:21 PM
92-Z28's Avatar
Car: 92 Z28
Engine: 350ci
Transmission: Th350
I got KYB AGX all around and I set the rear on 6 clicks and front on 2 lets just say it raise the front end like drag cars
Old Sep 23, 2012 | 10:13 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
what other mods do you have? lca relocation brackets? what about springs?
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
meeklay812
Oct 1, 2015 03:46 PM
