UMI and BMR A-arm geometory
Car: 92 camaro convertible z28
Transmission: Swapped from 700R4 to T5
Axle/Gears: Stock Posi. Ratio is not known
UMI and BMR A-arm geometory is exactly the same as the stock one?
Or do they change something, including ride height or alignment?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: UMI and BMR A-arm geometory
both are advertised as a stock replacement, so they should not change any pickup points, alignment or ride height
dude, please check your arm for sale thread...can you get back to me???
Car: 86 Trans Am
The arms i had for sale sold right after i posted them for sale
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
just got my new UMI A-arms today....they are nice!!!!!!!
Thanks for your replies
BTW, UMI and BMR are different in shape.
I think both are great, but which would you recommend if anything?
And I'm going to use the stock coil springs.
A spring compressor is a must, or just makes it easier to install?
Like mentioned above the a-arms are built to stock geometry. We did change the ball joint slightly to accommodate lowered vehicles. The spring pocket will keep the vehicle at the same height.
One main feature we offer that has been a great hit on our a-arms is the adjustable steering stops. They allow changes in steering radius for wider wheels/tires and is a pretty cool feature to have. I will post a picture below. Also you will find the UMI red and black to be a much glossier and higher quality powder coat than most of our competitors
I hope that helps, If I can help anymore please ask. Thanks!
Hello, Thanks for considering the UMI a-arms... we appreciate it.
BTW, more specifically, what kind of change did you make to its ball joints? Reinforced or something?
Also about adjustable steering stops, do they make any difference in the case of the stock tire size (245/50/R16)?
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
LT1Formula
Oct 8, 2015 08:34 PM
