Weight Jacks In Front
Old Feb 22, 2013 | 11:55 AM
83 Crossfire TA's Avatar
I know that there’s a couple of people here that have done it, and some that have some experience with the parts… I’m considering cutting out the front spring pocket and installing weight jacks, with the threaded rod coming through the frame rails, adjustable from inside the engine compartment. Any idea how much height they add to the spring package? Suggestions on parts to use? Pics? Links?
Old Feb 22, 2013 | 03:48 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
Re: Weight Jacks In Front
I put them in the stock k-member
https://www.thirdgen.org/forums/susp...g-vetruck.html
Berk put them in an aftermarket k-member
https://www.thirdgen.org/forums/susp...00lbs-its.html
I used Eibach 9.5" tall 5.5" OD 850# springs
Used this swivel cup weight jack
http://www.speedwaymotors.com/AFCO-S...bly,23487.html
http://www.speedwaymotors.com/WEIGHT...LATE,6509.html
I think you could easily use a 10.5" spring. I did everything from underneath - then ran at the track. One month later, started a LS2 swap and added/clean up some welds from up top. Swap time would be optimal time to do it, but not necessary. I did it on my back under jack stands. I used a cutting wheel, then an air chisel to cut the rind. Highly recommend increment cutting the rind, then hammer flat for welding like I show in my thread.
Brian
Old Feb 22, 2013 | 06:12 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Old picture I saved from a thread on here.
Just uploaded a few other photos that might be helpfull that Ive saved.
http://www.cecoatings.com/images/misc/weightjacks/
Old Feb 22, 2013 | 09:54 PM
Axoid's Avatar
Car: 92 Camaro RS
Transmission: T5 manual
The weight jacks pictured are ground control units.
http://www.ground-control-store.com/...hp/II=20/CA=86
I've had a set installed for years.
Old Mar 5, 2013 | 09:06 AM
MKM's Avatar
MKM
Car: 88 Trans-am GTA
Engine: 400 Small block
Axle/Gears: 3.42-3.73
I like the ground contol weight jacks I have had them for years. I did change the ones on the back to my own design this year much easier to adjust.
Old Mar 5, 2013 | 10:05 AM
RTLACY's Avatar
Car: 88IROCZ
Engine: 5.7 ZZ4
Axle/Gears: Moser 9" w/4:11 Posi
I used the same weight-jack/swiveler TEDSgrad used except I used Speedway springs as well. Same size etc. I did add a section of pipe to the hole in the frame rail in an effort to strengthen it some.
Old Mar 5, 2013 | 11:43 AM
SlickTrackGod's Avatar
On Probation
I love the irony of these boards. When you go to that link, you will see a ways down where Blyth in post #27 gives a link to this thread where I am RTFC.
https://www.thirdgen.org/forums/su...ght-jacks.html (Ground Control Weight Jacks)
Crossfire- Im sure you still have no clue what I was talking about, and you probably never will. I love experts that later come ask for help on the same subject.
But hey, good luck
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
NORTz89
May 20, 2020 03:51 PM
69 Six Pack
Oct 5, 2015 07:51 PM
