SFC, Strut Towers and Brace - Install Order
Old Feb 25, 2013 | 03:02 PM
RockShowTrader's Avatar
Car: 1988 GTA
Hey guys...
I have Spohn SFC's coming, as well as Strut Tower Mounts, Edlebrock Strut Tower Brace, and a Spohn Wonder Bar. I'm thinking I will give to the auto body guy with the following installation order:
1. Replace strut tower mounts (struts themselves are pretty new)
2. install strut tower brace
3. put car on frame machine, alignment
4. Install wonder bar
5. Install SFC's - weld in
Does that sound right? Any special instructions I should give them, other than what comes with each product?
Old Feb 25, 2013 | 03:53 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: SFC, Strut Towers and Brace - Install Order
Originally Posted by RockShowTrader
Hey guys...
Order they should be done in:
Old Feb 25, 2013 | 03:57 PM
Car: 1988 GTA
Thanks Paul. I thought you wanted to make sure the frame was straight before welding in SFC's.
Old Feb 25, 2013 | 05:33 PM
86firebird350's Avatar
Car: 91 GTA
Axle/Gears: stock
you do. it doesnt make sense to reinforce a subframe with SFC's if the chassis is out of alignment to begin with.
Old Feb 25, 2013 | 05:56 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Take note that you may experience issues between the STB and after market mounts, issues that may require modification to achieve correct alignment.
JamesC
Old Feb 25, 2013 | 07:56 PM
paul_huryk's Avatar
You definitely want the frame straight first. Was thinking it was already, then you just weld them in. Guess your wording about the body shop should have tipped me off...
Old Feb 25, 2013 | 11:26 PM
Car: 1988 GTA
So my order works?
Old Feb 26, 2013 | 03:35 AM
Twin_Turbo's Avatar
The order you have there is fine.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
TheExaminer
Aug 25, 2015 07:34 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
