perpetually loosening wheel
Old Mar 15, 2013 | 10:42 AM
mjd334's Avatar
Car: 1992 Chevy Camaro RS
Engine: 305 TBI 5.0L
I drive a 1992 Camaro RS. I recently replaced my wheel bearings and races because they had become too worn out to properly adjust. All was well and fine for about 3 days. Since then the nut responsible for securing the rotor to the axle keeps loosing itself until my wheel developed a dangerous 1'' play. I have re-tightened the nut several times and have the castle nut and cotter pin properly seated. When i re-tighten the nut the wheel wobble is eliminated.
What is causing this nut to loosen up after only a few hundred miles? What can I do to correct the situation?
Thanks!
Old Mar 15, 2013 | 11:14 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: perpetually loosening wheel
How did you set the bearing preload?
Old Mar 15, 2013 | 11:26 AM
mjd334's Avatar
I did as the manual suggested. Spinning the rotor and turning the nut until snug. Then back it of a bit
Old Mar 15, 2013 | 12:17 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
A castle nut with a cotter pin through it can't loosen without the pin shearing. You've done something wrong in installation.
Old Mar 15, 2013 | 06:00 PM
87350IROC's Avatar
Car: 87' IROC
Take a picture of how you have everything installed. Particularly the castle nut and cotter pin.
Old Mar 16, 2013 | 03:54 PM
rawley2's Avatar
Car: 87 GTA Trans Am
Axle/Gears: 10 bolt posi 3.23
Did you seat the races? Sounds like they are pushing in.
Old Mar 20, 2013 | 01:46 PM
83 Crossfire TA's Avatar
yea, like some of the others, I'm kind of curious what you're doing... with the cotter pin installed (nut properly installed...) it can't come loose, I don't think you could shear the pin trying to remove it with an impact gun, much less just driving it.
Old Mar 22, 2013 | 02:26 PM
mjd334's Avatar
it would seem that the races were not properly seated and were indeed pushing in as i drove. That is what caused the space and the wobble. A bit of adjustment fixed her right up! Thanks guys
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
Fox118
Sep 12, 2015 09:29 PM
WickedBowtie
Sep 11, 2015 11:24 PM
punkmaster98
Sep 8, 2015 09:45 PM
TBRays98
Sep 6, 2015 05:05 PM
