An idea I just had
Old Apr 18, 2013 | 07:02 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Axle/Gears: 9 bolt posi 3:27
An idea I just had
Don't laugh I did when I thought about it but then I really thought about it. What if I where to pick up the correct pieces and using the stock lower A-arms cut and weld in adjustment points to the ends the connect to the K-member. Like maybe some ball joint ends. Boom cheap yet reliable adjustable A-arms. If it works the same could be done with the rear LCA's just make sure that everything is straight before you weld and it should be ok. What do you guys think anyone try this?
Old Apr 18, 2013 | 07:26 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Re: An idea I just had
Hell no.
Old Apr 18, 2013 | 07:37 PM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
What's the purpose of adjusting A-arms? LCARBs are already made for LCAs.
Old Apr 18, 2013 | 08:14 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
deal, just a thought I had. Just gonna get a coil over kit and call it a day then
gta892000
Aug 11, 2019 11:16 AM
Fox118
Sep 12, 2015 09:29 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Djmathis123
Sep 8, 2015 08:42 PM
