Been battling this front end issue for months
Old Apr 18, 2013 | 08:22 PM
Cmbmt's Avatar
Car: 89 camaro RS
Engine: 2.8l soon to be changed
Transmission: T5 manual
I can't figure out whats wrong. I bought my 89 v6 RS with big plans in mind and can't even get past this. The best way to explain it is when ur in a truck with 4x4 engaged and you turn really sharp and it hops. I've replaced the ball joints and had it aligned and it still has issues. It has a non posi rear end as well. Any ideas? the idler arm is a touch loose.
Old Apr 18, 2013 | 08:30 PM
n1ffer's Avatar
Car: 1983 Crossfire Recaro T/A
Engine: 5.0L Crossfire
Transmission: Upgraded 700R4
Axle/Gears: 3:23
Re: Been battling this front end issue for months
What is the rim size and tire size? Sometimes a too wide or tall tire can scuff on tight low speed turns. My 83 doesn't seem to suffer from this, but my 82 used to do that. I had P215/65/15 on the 82 and they scuffed. I have I think P245/50/16 on my 83 and no issues.
It was strange. I just learned not to over turn at creeping speeds with the 82. I never had any other problems or any worn or unsafe suspension issues. Drove it for probably 60k miles or so and never had any front end issues.
My 83 has a completely new front suspension. That may be why it doesn't.
Not sure if I helped, but can at least understand!
lol
Old Apr 18, 2013 | 08:35 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The problem is common to our cars.
The following is from How to Tune and Modify your 1982-1998 Camaro by Jason Scott:
"The problem stems from high forces transmitted from the steering box to the chassis, especially under low-speed cornering, such as when maneuvering around a shopping mall parking lot. Fat performance tires present a great deal of resistance at low speeds, which imparts considerable stress into the steering system, and ultimately attempts to rip the steering box from its mounting surface--especially during "full-lock" turns, where steering torque is greatest. Over time, these forces weaken the chassis surface around the steering box and can result in torn metal.
"Whether the chassis is weakened or torn at the steering box, the result is the same--steering actions are delayed while the chassis flexes, leading to unresponsive and erratic steering. Ironically, though the damage stems from low-speed steering, the resulting problem is far more serious at high speeds than low ones.
"It is possible to repair the damaged area, though the best solution is to avoid the problem in the first place by installing a brace that reinforces the steering box mounting area."
The brace mentioned in the last paragraph is a steering box brace, aka, the Wonderbar.
JamesC
Old Apr 18, 2013 | 08:36 PM
Cmbmt's Avatar
Car: 89 camaro RS
Ill have to check that out. I know that they are P215/65/ R15
Old Apr 18, 2013 | 08:44 PM
Cmbmt's Avatar
Car: 89 camaro RS
Where do I find a brace or how do I fab one?
Old Apr 18, 2013 | 08:52 PM
n1ffer's Avatar
Axle/Gears: 3:23
JamesC
That's a great point about the wonder brace. I know my 83 has one and I do not believe my 82 did. It would make sense that the wonder bar would help out with that situation.
A good day - I learned something! lol
Old Apr 18, 2013 | 08:54 PM
n1ffer's Avatar
Axle/Gears: 3:23
You can fab one, search for a used on one on EBay or Craigslist, or buy an aftermarket.
I think mine is from Spohn Performance, although I would have to crawl under there to look and be sure.
There are other aftermarket makers. I think Top Down Solutions (TDS), UMI Performance, Hawks Third Gen, etc. have them.
A great upgrade!
Old Apr 18, 2013 | 09:06 PM
Cmbmt's Avatar
Car: 89 camaro RS
Sweet thanks guys! Time to research!!
Old Apr 18, 2013 | 09:23 PM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
my 92 does that. It goes to the body shop monday to have the frame repaired behind the steering gear box. I'm curious to see of it will stop after it's repaired.
Old Apr 19, 2013 | 12:43 AM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
UMI Performance is on this website, just asking Ryan he can help you out, fantastic person to deal with
Old Apr 19, 2013 | 06:20 AM
JamesC's Avatar
The OE steering box brace, aka the Wonderbar, didn't arrive until 85 with the introduction of the IROC and its 16" wheels.
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
bellez77
Sep 5, 2015 08:39 PM
mizz0313
Aug 12, 2015 06:45 AM
