Lowered guys, Distance between your front tire and fender
Old Apr 22, 2013 | 05:49 PM
Buggy Disaster's Avatar
Car: 91' Z28. 70' Dune Buggy
Engine: LSX Cam/Full Bolt ons
Axle/Gears: 4.10
I'm ready to lower my car and get my perfect stance.
I am not worried so much about the chin spoiler or under carriage bottoming out since I am running a larger wheel. I'm just concerned about the top of the tire rubbing the front fender. What is a safe distance from the top of the front tire to the fender?
I'm running moog 5662 with KYB GR2 struts.
I know what I am asking is VERY vague and allows many variables, but I just want a generalization before I start cutting.
I tend to over think things.
Old Apr 22, 2013 | 07:00 PM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
Re: Lowered guys, Distance between your front tire and fender
Larger wheels only make a difference if the diameter of the tire is larger. 25.7" is average tire diameter. Check the lowered 3rd gens thread here in the suspension board. Quite a few fender height measurements in there.
Old Apr 22, 2013 | 07:02 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
what tire are your running? that will tell a lot
Old Apr 22, 2013 | 08:12 PM
Axle/Gears: 4.10
I should of worded it better, I'm not looking for fender height, I'm looking for fender gap. I've gone through the lowered thread a while back and didn't see much about fender gap measurement. I will look again
sailtexas186548
I'm running a 245/35/19 up front. Its 26" tall. My fender is at 28.5"
Old Apr 22, 2013 | 09:04 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
I have oem 25.65 tires. Front fender height = 26.75; rear = 27.5
245 tire tucks in and no rub.
Do you have tall strut mounts? What struts?
I don't have the determination or patience to fiddle with springs in and out, in and out; equalizing sides (forget about scaling)--> Weight jacks
Old Apr 23, 2013 | 08:54 PM
Axle/Gears: 4.10
plum92_camaro, I re-read your post and realized what you meant. If my tire is 26" tall then the fender heights in the lowered thread will apply to me.
TEDSgrad
I don't have tall strut mounts, and I'm running new KYB Gr2 struts. I'm now wishing that I went with weight jacks instead of buying new springs. So about an 1.25" seems safe. I am looking for that lowered look.
How much would a weight jack kit cost for just the front?
Old Apr 23, 2013 | 09:15 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
weight jack here: http://www.speedwaymotors.com/AFCO-2...bly,23487.html
plate goes with: http://www.speedwaymotors.com/WEIGHT...LATE,6509.html
Here's my install: https://www.thirdgen.org/forums/susp...g-vetruck.html
Not for the faint of heart, but it's better and cheaper than the ground control route, which most do. You'll need to cut, grind, and weld; otherwise, go with ground control. These articulate (swivel cup) and have less unsprung weight to them.
Old Apr 23, 2013 | 09:19 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
http://www.spohn.net/shop/1982-1992-...ut-Mounts.html
You should do these first - low hanging fruit. While you have the front end apart, do the weight jacks.
Old Apr 23, 2013 | 10:04 PM
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
Originally Posted by TEDSgrad
... do the weight jacks.
What that is?
Old Apr 23, 2013 | 11:05 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Originally Posted by IROCgiraffe
What that is?
Shorter than standard springs, with threaded adjustable pieces so that you can simply twist to raise or lower a car to set the height where YOU want it, not where the spring manufacturer says it will be. These are the drop-in Ground Control units.
Old Apr 24, 2013 | 06:14 PM
Axle/Gears: 4.10
TEDSgrad I went through your thread and that involves too much fab work for me. I can't weld so I would have to have a shop do all of that for me.
So drop in ground control seems the way to go, however I'm not willing to spend $400 for front and rear at the moment. I can't find anyone that will sell just the front either.
Would it be a bad idea to have a fab shop make some for me?
Old Apr 24, 2013 | 06:40 PM
midnightfirews6's Avatar
Car: 1984 Trans Am WS6
Engine: LG4
Axle/Gears: 3.23 LSD
It's been discussed in a few threads, and if they're done right it's okay. A company called Allstar makes rear adjuster parts and you can put two together for about $80, so after that you'd only need the front adjusters. Springs are about $60 a piece, so you're looking at $240 for all 4 corners there, $320 with the rear adjusters included. If you could find a good shop that knows what they're doing to make the front two for you for under $130 you'd come out ahead. On the other hand, the GC setup is shiny and powdercoated, ready to go out of the box, and has a lifetime warranty.
Old Apr 24, 2013 | 07:11 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
The usual dilema; own time & labor vs paying out.
If you can get a jy k- member, shouldn't be too much to have those plates welded in for you, then swap k-members.
Always thought someone could make money fabing them up, especially notched for swaps.
Old Apr 24, 2013 | 09:48 PM
Car: 92 Camaro RS
I have ground control weight jacks. I installed them with Koni yellows and Hotpart/J&M products caster camber plates. The raised strut mounts and Koni's don't hang/extend as far as stock. to much preload and too close to coil bind for me to get to stock height but I'm ok with that. I bought them to go lower and perform well.
Old Apr 25, 2013 | 02:33 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Here's a pic from today. Use the bucket (lower left) and bench as height guides.
Attached Thumbnails Lowered guys, Distance between your front tire and fender-dsc00583.jpg
Old Apr 25, 2013 | 06:28 PM
Engine: LB9 | LS1
Looks perfect!
Old Apr 25, 2013 | 07:02 PM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
I run a 23.8" tall front tire, and can just slide my hand between the tire and fender. NO rubbing but it is LOW. A taller tire and it would rub
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
