kyb or bilstein
Old Apr 26, 2013 | 10:49 PM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
kyb or bilstein
Who has what and how do u like them? In ct the roads are awful. I have plly all around and its time to do the struts/ shocks. I don't mind a firm ride but bone jarring isn't good when I'm out on a family cruise. Let's hear pros and cons.
Old Apr 27, 2013 | 07:50 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: kyb or bilstein
Bilstein are light years ahead of KYB, and are lifetime warrentied, they will rebuild them.
Eithere are a great improvement over worn units.
Only con to Bilstein is the price, but you will never have to buy them again.
Old Apr 27, 2013 | 09:03 AM
BlackMamba's Avatar
Car: 84 Camaro Z28
Engine: 355 Carb
Re: kyb or bilstein
I'm running KYB on my car
There are a good bang for your buck
The KYB on my car are still the same the same ones my father installed 12 years ago and they still doing their job well
Old Apr 27, 2013 | 11:18 AM
Manic Z's Avatar
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
Re: kyb or bilstein
I have the KYB AGX front struts. Had them installed about 8 years ago, and they`re still performing perfectly. Love the adjustability too.
Old Apr 27, 2013 | 01:03 PM
Car: 91 formula ws6
Transmission: 4l60E
Re: kyb or bilstein
The price is steep. I do one major overhaul per year and this year I've noticed some instability and to me feels like the 3 year old Monroe units are just not cutting it. I've installed bilsteins on a lot of customers cars and the difference is more stability. I've never used the KGB agx but I noticed a big difference in price and I've Seen decent reviews from threads on here. I didn't like the gr2 series tho.
Ps. - I don't mind spending the money. Just I've noticed a lot of people seem to run them as your footnotes say. Lol
Old Apr 27, 2013 | 03:42 PM
Anti-Venom's Avatar
Car: '89 Formula WS6
Transmission: 700r4/T56
Axle/Gears: BW 3.23
Re: kyb or bilstein
Kyb's or Tokiko's are both a decent factory replacement, where as Bilstein's are a high performance unit that will feature more accurate/consistant valving and reduced cavitation. Unless your going to be racing kyb would be a good choice.
Old Apr 27, 2013 | 04:47 PM
Car: 91 formula ws6
Transmission: 4l60E
Re: kyb or bilstein
Only racing I plan on is road rage. I do enjoy a good spirited cruise occasionally around some twisty corners. I also plan on the founders strut mounts. Just like how sturdy they look. Any opinions?
Old Apr 27, 2013 | 05:02 PM
ZF6camaroZZ4's Avatar
Car: 86 Z/28 IROC-Z
Axle/Gears: 9 Bolt 3.27
Re: kyb or bilstein
Bilstein also has the huge outer shaft for better side load support. Instead of just the small shaft.
Theres a pic in the for sale section.
https://www.thirdgen.org/forums/engi...ts-3rdgen.html
Bilstein has good customer service. 100% behind there lifetime warranty, can also re-valve them anyway you want, all though the warranty goes away.
Old Apr 27, 2013 | 07:50 PM
Car: 91 formula ws6
Transmission: 4l60E
Re: kyb or bilstein
those look beefy. what happens if you buy them second hand tho? do they still honor the warrantee?
Old Apr 27, 2013 | 07:52 PM
Re: kyb or bilstein
A Fiat or a Mercedes? hmmm..... not sure which is .... better .... ???
But if you're really going to bite off, look at the Koni yellows instead.
Old Apr 27, 2013 | 08:39 PM
Car: 91 formula ws6
Transmission: 4l60E
Re: kyb or bilstein
That's another brand I've seen often. I prefer handling over raw power if I had to make the choice.
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
tcflint
Sep 27, 2015 05:58 PM
87camaro87
Sep 9, 2015 10:29 PM
