clattering steering wheel
Old May 16, 2013 | 06:15 AM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
Something interesting is occurring with my steering. At certain times (Im not sure if it speed related or road conditions) my steering wheel clatters left and right like those wind up gag teeth. Any ideas what could cause this? Is a rag joint going out? The steering wheel itself isn't loose, the wheel just clatters intermittently.
Any ideas would be most appreciated.
Thanx in advance.
Old May 20, 2013 | 02:25 AM
Veaceonee's Avatar
Re: clattering steering wheel
No one? Could it be tires?? This problem is getting worse.
Old May 20, 2013 | 05:48 AM
rawley2's Avatar
Car: 87 GTA Trans Am
Axle/Gears: 10 bolt posi 3.23
It could be MANY things.
Jack your car up and see what is loose.
or
Have someone move the wheel back and forth and you look and whats loose under the car.
Really hard to guess but when your checking things don't forget to look at your wheel bearings to make sure they are still tight.
Old May 20, 2013 | 02:27 PM
87 Camaro Dude's Avatar
Car: 1987 Camaro SC
Engine: 2.8L V6
Like rawley said, could be many things. Another thing to check is to see if a wheel weight has fallen off, that would cause the tires to become out of balance and could cause steering wheel vibration.
Old May 20, 2013 | 02:39 PM
SlickTrackGod's Avatar
On Probation
Definately something is severely worn in the front suspension pivots or bushings. Either a ball joint or a strut mount that will aloow the wheel to wobble violently. When the wheel wobbles, it sends the vibration through the steering linkage assembly and thus up through the steering shaft to the wheel.
Old May 20, 2013 | 03:43 PM
Veaceonee's Avatar
The intermediate steering shaft has some play in it. I am going to do the Cherokee shaft swap tonight (I know the Astro is better, but the Cherokee requires no specialized modification). It is going in tommorrow for new tires, balancing, alignment, etc. We will see.
Old May 20, 2013 | 07:52 PM
On Probation
Before you pay for an alignment, request they check your strutmount bushings and balljoints, basically give the car a quick lookover underneatht he front ot see it it even warrants a gauranteed alignment. If they do the alignment and something is worn, it will still not matter and you will be out the money.
Old May 20, 2013 | 08:55 PM
Veaceonee's Avatar
The alignment is a package deal with the tires. But, I will have them check it out anyways. Got the Cherokee steering shaft in, went around the block, BIG difference. Hopefully tires will clear up everything else.
83 Crossfire TA
Jan 3, 2016 01:26 PM
SG91camaro
Sep 5, 2015 10:27 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
