Strut shaft doesn't go far enough up through the mount
Old Jun 8, 2013 | 06:17 PM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
How you guys doin.
I noticed my struts don't have any exposed threads after I tightened the nut. When I seat the bearing onto the shaft I can feel it kind of "pop" in place. There is no stock cover blocking the shaft from moving up more. I don't know what the problem is. I'm using kyb struts with UMI camber/caster plates.
I know these images aren't perfect, best I can provide; sorry.
Anyway:
I've never done this before so let me know if you see something out of place
Let me know if you need any more info/pics. Thanks for your time.
Old Jun 8, 2013 | 07:40 PM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
Re: Strut shaft doesn't go far enough up through the mount
My koni yellows and hotpart (same design) strut mounts seemed the same way. The threads reached the nylock of the nut so I called it good.
Old Jun 8, 2013 | 08:04 PM
0pyders's Avatar
Yeah I can't feel any more thread underneath I guess that's how it's made.
Frozer!!!
Jan 19, 2024 04:55 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
MENINBLK
Aug 5, 2015 11:58 PM
