Just installed some Koni Yellows on the rear
Car: 1989 Camaro Iroc Z
Axle/Gears: 9 Bolt Borg Warner/ 2.77 gear
and WOW! Now my tailbone doesn't hurt everytime I hit a bump, and I can take curves fast without the body roll. Do Koni's raise the ride height because I lowered the car with eibach sportlines and now the rear went up about an inch. Also, how do you tell what setting the Koni's are on? There is 1,2, and 3.
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: Just installed some Koni Yellows on the rear
The Konis are gas filled, so they raise the car a tiny bit. There are actually 0, 1, 2, 3 settings on the rear Koni shocks. They come stock set at the 0 position.
http://www.koni.com/car-racing/technology/adjustment/ (read about the 30 series)
Thank You, that really helps.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Did you get the 3rd gen or the 4th gen ones? 4th adjust with a ****...
hectre13
12-11-2023 08:14 AM
hectre13
08-26-2015 08:17 AM
