Got my moog ball joint in, but did I do it wrong?
Old Jul 6, 2013 | 04:13 PM
whatdayasay's Avatar
I was having trouble getting my moog ball joint to go in straight. I was pressing on the outer ring which looked like good steel. The instructions said not to press on the name plate which I think is the softer metal inside the outer ring and their is writing on it. I had most of the joint in and it was crooked but couldn't make any progress after numerous attempts, so I switched my rigging to push on this big center portion (copper in color) and it went right in because i think the force was closer to where it was needed. Did i do this right or wrong?
Old Jul 8, 2013 | 10:03 AM
marta85's Avatar
Re: Got my moog ball joint in, but did I do it wrong?
if nothing looks bent you're likely fine, but yeah you should only push on the outside circle I believe.
Old Jul 8, 2013 | 12:05 PM
thanks
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
Ed1LE
Sep 30, 2018 09:14 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
