Strut tower sandwich. Good idea?
Car: 1985 Camaro Z28
Engine: 5.7 LSX
Transmission: Performabuilt 4L60E
Axle/Gears: Strange 12-bolt 3.73
So I installed a BMR coil over front
suspension kit and I believe (not
certain though) that the install
called for both plates to be up top
but I decided it would probably be
stronger to sandwich the tower with
one plate on top and one underneath.
My question is, is this how it is
supposed to be? If not, is this a
better way? And how will this affect
any alignments I get? Any help here
is appreciated. See the attached pics
for reference. Thanks!
P.S. I will also be installing a strut
tower brace when it's all done.
Engine: 5.7 LSX
Re: Strut tower sandwich. Good idea?
Here's another pic I couldn't attach in the first post...
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
I would suspect by the design of that plate it doesn't make a difference either way.
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
I know of some people who have welded around the strut tower to reinforce that, but I'm not sure if that entirely necessary.. The plates should do a good enough job.
Engine: 5.7 LSX
Sounds good, thanks! Now I assume
that alignments will still be easy?
I'm not sure how they are done but
the bottom plate does not have a
whole lot of room to move. Maybe
a quarter inch in all directions if it
needed to be adjusted.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
