help were is the rear shock bolt mounted????
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: help were is the rear shock bolt mounted????
On top of the rear hump behind the rear seats. Pull the carpet back and u will find 2 foam covers up against the interoor plastics, top bolts are under them.
Car: 86 Trans Am
This is very simple. Pull the carpet up from behind the back seats, right at the top of the hump, right behind the outside corners of the seats are the bolts. It took longer to type this than it does to get to them.
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Check out the #7 response on this thread. The whole thread has great info. Good luck.
https://www.thirdgen.org/forums/susp...nsion-how.html
Eric-86sc
Apr 3, 2016 03:52 PM
