'Coleman Racing' aluminum tie rod sleeves
Old Sep 20, 2013 | 11:04 AM
eyeroc87's Avatar
Car: 1987 IROC
Engine: 5.7 TPI
Axle/Gears: 9 bolt 3.27s
I bought a set of CR alum. tie rod sleeves, and as Ive here posted before. They where not taped all the way thru and the tie rods wont go in far enough for proper toe setting.[PLEASE no opinions on alum. VS steel, Ive read em-Ive heard em, that's not the point] After calling and talking to Lary. he suggested cutting the tie rods, He suggested taking the aluminum sleeves to a machine shop and have them tapped out. When I ask if this was a common problem. I never really got answer. My point is, Ive read several threads on here that recommend CR sleeves. My front end is completely rebuilt new and all stock 'except for the sleeves' the Coleman sleeves don't fit and there not standing behind them.." BE CAREFULL" with Coleman Racing.
Old Sep 20, 2013 | 01:03 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 'Coleman Racing' aluminum tie rod sleeves
Their sleeves are not made for any specific application so its not their fault it doesnt work for you, that should be pretty obvious.
Cutting the tie rods a little wont hurt anything, unless you can simply just grind the end down a little like I suggested to you before. The other option would to to eliminate the outer tie rod completely and use a lonfer sleave, I think 9" is the right length, use a 5/8 rod end for the outer and get a bump steer stud and safty washers for the sreering arm. This way you save some more weight, and have bumpsteer adjustment as well.
Old Sep 21, 2013 | 12:51 PM
87350IROC's Avatar
Car: 87' IROC
Coleman Racing sells universal fit racing parts. It is up to the purchaser to understand their own needs. If you do not understand this I would recommend just buying tie rod sleeves from one of the companies that sells direct fit parts. Second solution would be to just tap them all the way through, whats the big problem with this? Aluminum is easy to tap.
Old Sep 22, 2013 | 07:39 AM
Lonnie P's Avatar
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
Finding a left hand tap will not be cheap.
I bought a set of steel sleeves & new Moog tie rods & had the same problem.
It's not the manufacturers fault, when you start modifying things, you have to expect this.
Not sure what the big deal is here.... just cut the tie rods slightly.
A few minutes with a saw & a file to dress the end threads & everything will work fine.
Old Sep 22, 2013 | 11:39 AM
87350IROC's Avatar
Car: 87' IROC
Yup, more than one way to skin a cat for sure. Mostly likely he wouldn't need a left hand tap, you can just lengthen the right hand thread side and just thread on the right hand tie rod further. Or just get the LH tap from McMaster for $34.
Old Sep 23, 2013 | 10:08 PM
Lonnie P's Avatar
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
True, I settled for a $3 hacksaw blade & 10 minutes of work.
GTAman
Jul 3, 2024 07:29 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
scottmoyer
Sep 7, 2015 07:06 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
