Motor Mounts
Motor Mounts
Can anyone recommend a good pair of motor mounts for a L98 88 iroc with roughly 350hp to the wheels.
http://www.summitracing.com/search/y...rder=Ascending
I find these but so far all the polly mounts require your to use your existing clam shell from your stock mounts. Do any come per-assembled with Poly mounts??
Re: Motor Mounts
Stock ones work fine at that power level.
Poly wouldn't be too bad either.
What's so bad about using your existing clam shell? Just enjoy it when your garbage cans weigh more?
Re: Motor Mounts
Personally, stock or solid, I don't really see the point of poly. Poly tends to cold flow and it's also less heat resistant than rubber, and if you're having heat, clearance or want to make your engine block part of the chassis, then swap in solid.
ambainb
Apr 25, 2016 09:21 PM
NBrehm
Aug 5, 2015 07:57 PM
