92 rear end SWAP
Old Oct 13, 2013 | 05:15 PM
mfoge5's Avatar
92 rear end SWAP
Ok I am getting ready to swap the rear end in my 92 rs for a 96 z28. I have been reading all the threads and think i pretty much got it down my question is about the proportioning valve. Just to clarify i am going to need one for a 96 or one for the disk brakes now or can I just change the spring inside ??? i know its a dumb question but I just want to make sure I get it right. And also the brake cables should I get them off a 96 also??? And these are the only things that I will need to change for the swap right...
The info you guys provide is priceless and I couldnt do the things Ive done on my own without it.... Thanks ......
Old Oct 14, 2013 | 09:19 PM
myroc86's Avatar
Car: 86 Camaro
Engine: 350 LT1
All you will need to get is get a disc brake prop valve. Might be easier to just get the whole master from a disc brake car. Just depends on what you want to spend and your resources. As for the cables you could try Ed, but if you plan on finishing the car in the next few years I would wait for someone else will chime in on that. Good luck with the swap.
Posted from Thirdgen.org App for Android
Old Oct 15, 2013 | 07:35 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 92 rear end SWAP
Originally Posted by mfoge5
Ok I am getting ready to swap the rear end in my 92 rs for a 96 z28. I have been reading all the threads and think i pretty much got it down my question is about the proportioning valve. Just to clarify i am going to need one for a 96 or one for the disk brakes now or can I just change the spring inside?
Since you'll essentially be using 89-92 PBR's (93-97 are nearly identical), use the 89-92 second design disc combination valve. It must be the second design or the tube nut threads won't fit your car. More info on the topic, to incude master and parking brake cables, below:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
I have no experience with the spring swap.
JamesC
Old Oct 15, 2013 | 01:09 PM
mfoge5's Avatar
I can get my hands on a 95 master cyl. For 10 bucks . But just the M.C. can I use it with my booster etc.??? Thanks again guys you always come through..
Old Oct 15, 2013 | 01:33 PM
ssean92's Avatar
Car: sold
I used my factory 92 rs one with no issues at all
Old Oct 15, 2013 | 04:29 PM
JamesC's Avatar
Check out the info about masters in the following link--hey, GM says either a drum or disc master one could be used, depending on how the owner wanted pedal feel.
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
hectre13
Dec 11, 2023 08:14 AM
IroczFan
Oct 6, 2015 10:13 AM
hectre13
Aug 26, 2015 08:17 AM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
