is this normal???
Old Nov 12, 2013 | 03:22 PM
Stauf's Avatar
Car: 91 Z28 Coupe
is this normal???
While looking at my car today, I noticed that my passenger side rear wheel/tire sticks out about 1 1/2" - 2" further then my driver side rear. Car is totally stock, never i n any accidents. 2.73 rear posi. 91 Z28 coupe
Posted from Thirdgen.org App for Android
Old Nov 12, 2013 | 03:56 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: is this normal???
Not normal, sounds like the panhard bar is bent. It locates the rear axle side to side.
RBob.
Old Nov 12, 2013 | 08:12 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
50/50. The diff isn't centered under the car 100% but with everything stock, it shouldn't be that noticeable. If you stick wider tires/rims on the car, it becomes a lot more noticeable how much the stock diff isn't centered.
1-1/2 to 2" may be a little too much. As mentioned above, check for a bent panhard bar or upper brace.
Fanatic1074
Oct 3, 2022 05:57 AM
Linson
Oct 1, 2015 09:50 PM
dusterbd
Sep 29, 2015 08:40 AM
BWilcox
Sep 20, 2015 12:19 PM
Stroopwafel
Sep 11, 2015 06:38 AM
