Rubbing issues
Car: 1991 RS/B4C clone
Engine: 355 TPI
Transmission: Probuilt Street/Strip 700r4
Axle/Gears: 7.625 axle with 3.23 gears/TrueTrac
Rubbing issues
I've been searching for solutions to this issue. I recently switched to a wider wheel (Ronal R15/275/40/17). Initially when I had the Hankook Ventus tires on the car, I did not have a significant rubbing issue. I switched to Toyo Proxes R1Rs as well as I changed my steering box to a Lee 670 steering gear.
At my first autox event with this setup I rubbed the inner fender well on the passenger side pretty good (the course had a 180 that you pretty much had to go full lock to navigate). It rubbed it bad enough that it popped the ground effect from the metal retainer on the fender... the only solution I could think of for this is some type of adjustable steering stop; I've seen someone on the board do it but that was a few years ago. Aside from that, how have any of you addressed this issue?
(I already searched)
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Rubbing issues
How much caster are u running? The tire should be nowhere near the fender where it would cause that kind of damage
83 Crossfire TA
Sep 8, 2015 12:06 PM
