What to paint rear end with? It is a Moser 12 bolt that currently is painted in POR15
Old Feb 13, 2014 | 11:54 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
I don't really like POR15 and am hoping to find something better, maybe more durable. What are you guys using? Most of my other parts are powder coated read (spohn parts, or PA racing). What are some alternatives you guys have had good luck with?
Thanks.
Old Feb 13, 2014 | 12:12 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Re: What to paint rear end with? It is a Moser 12 bolt that currently is painted in P
I'm Interested In This Also,Not Sure Which Is More Durable, A Lacquer Or Enamel Paint.
Old Feb 13, 2014 | 12:20 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Check into Zink plating
you can get yellow or silver.
the yellow/gold zink is the same stuff you see on alot of oil pans..has the light hits it. Ya can see greens. Blues. Yellows... and its rust proof for life..and cheap.. the place by me will do a rear housing for $65 if you blast it before dragging it in.... $100 total for them to do it all.
Old Feb 13, 2014 | 12:25 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
I used an enamel paint with hardener on mine. I forgot the brand right now, but its called Tractor and Implement paint I got from Tractor Supply. It's for farm equipment and cures nice and hard. I dropped a pry bar on mine from about 3' high by accident after it was painted and it didnt even scratch it. After 2 summers of driving, it still looks great. It's not a high gloss paint, but not really a matte either, and you can get it in several colors.
Old Feb 13, 2014 | 10:12 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Tremclad Hammertone!
I just painted my roll cage with it. It's very hardy
Old Feb 14, 2014 | 08:21 AM
Pocket's Avatar
Car: 91 Trans Am
Tractor paint is tough stuff. I paint all my blocks, suspension and SFC bare metal with it. A tip, buy a bunch of cheap dust brushes from harbor freight to apply it with. It will ruin a good brush quickly and since it smooths itself out, brush quality doesnt make any difference. 98 cent HF special vs $9 Purdy...
One quart at $12 will do the engine and all suspension for about two cars
Old Feb 14, 2014 | 08:31 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
I used a spray gun for my rear axle, never tried brushing it on anything yet.
Old Feb 14, 2014 | 11:33 AM
Engine: LS3
So far looks like tractor paint is in the lead. Who knew.
Old Feb 15, 2014 | 12:25 AM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
I always repaint mine with the OEM paint the parts place has and you can also get it here http://www.ebay.com/itm/GM-Black-Chassis-Reconditioning-Paint-1050104-Corvette-Chevelle-Camaro-Impala-/291080667357?pt=Vintage_Car_Truck_Parts_Accessories&hash=item43c5c280dd
Old Feb 15, 2014 | 08:43 AM
gt4373's Avatar
Starting Bid $99.00,Wow Not Cheap.
Old Feb 15, 2014 | 05:08 PM
Engine: LQ4 ls 6.0
Its just like anything else you get what you pay for if you think thats bad I spend around $1200.00 up on paint just to paint a car
Old Feb 15, 2014 | 06:14 PM
Engine: LS3
My car was 3600 dollars that was back in 2006! Rear end was 2100. Next paint job will hopefully be less...
Old Feb 16, 2014 | 08:39 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
POR 15 is way more durable than any of that stuff... But if you insist on doing something else you are going to have to completely strip off the existing POR 15, nothing with stick to it even if it's scuffed. If it was poorly prepped and the por15 is coming off, then keep peeling.
Old Feb 16, 2014 | 10:19 AM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
this is surprising since por 15 says to overcoat it if used in sunlight.
Old Feb 16, 2014 | 10:58 AM
Pocket's Avatar
Car: 91 Trans Am
Yeah, and POR15 is made to be used on poorly prepped areas. The name stands for Paint Over Rust
Old Feb 16, 2014 | 11:41 AM
kerplunk318's Avatar
If you were willing to tear it down, I would say have it blasted and powder coated. EDIT: I am an idiot and misread the OP, but I will see if I can dig up pics of my 12 bolt after it was powder coated gloss black.
Old Feb 16, 2014 | 03:24 PM
tvc 15's Avatar
Car: 88 rs
Engine: ls1
Transmission: t56
Axle/Gears: moser 4:10
POR has no UV protectors in it so if you use it in sunlight it will fade unless you overcoat it with another product. But if it's used under car it holds up very well.
Old Feb 17, 2014 | 08:09 AM
stealtht/a's Avatar
Wrong.
POR 15 paints over RUSTY, prepped, metal. The scale must be removed, ALL paint and grease must be removed, rust is nuetralized with acid and it must be BONE dry!
Por15 is great stuff, but if you can't read directions, don't bother, you'll screw it up. You must follow the prep instructions to the letter for good results.
Once por15 is cured, it's almost impossible to get anything to stick to it.
They recently introduced a product called tie coat that is supposed to allow it to be top coated with reg paint, but even their own description doesn't make it sound foolproof, so I haven't tried it yet.
Basic POR 15 with fade in uv and eventually break down after a really long exposure. They instruct to top coat BEFORE final curing using their products such as Chassiscoat. These products are not as good at bonding to metal, but are still very tough and seal the por15 and protect it from uv. Once the por15 has cured, even their topcoats won't stick to it well.
Por15 is all about tying the layers together by applying at tacky stage so that it does not inhibit the curing, but bonds to the bottom layer.
So to relate this to original post, POR 15 is the best for protecting metal, but it can be difficult to apply properly in some situations, making it inefective.
Old Feb 17, 2014 | 11:11 AM
Engine: LS3
I agree, it is good when it is easy to apply. Upside down, is tough I think. I need to do my entire underbelly as well
Old Feb 17, 2014 | 05:04 PM
83 Crossfire TA's Avatar
it will stick to itself, so the trick used to be to give it a coat and then top coat it with whatever you want to use within about 30min or so.
I've wondered if there was a good way of retarding drying so you can spray it (you can get it sprayed, but I'd be suprised if you can get it cleaned out of the gun in time to keep it from getting ruined as it comes out of the can). If you're going to do the underbody of the car with it with a brush cover up well- it will drip and anything you get it on will be that color for a long time.
One of my favorites for this kind of stuff is rustolium hammered paints- fairly easy to apply, and as long as you put on a heavy enough coat to get it to dry hammered relatively foolproof, durable and when you do scratch it up just brush some on and it hides the scratches.
Old Feb 18, 2014 | 07:43 AM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Rust-Oleum Hammertone here....turned out pretty nice and doesn't show dirt as bad as going with a standard black.
Old Feb 18, 2014 | 07:57 AM
stealtht/a's Avatar
30 min is too soon, it will inhibit curing of the por15. You want to apply topcoat when it is past tack to "finger drag", usually about 3 hours. Not ideal for top coating still as you have brushed or rollered the por 15, so spraying color on top will only highlight the surface flaws. They do have choices of colors in chassis coat.
You can mix POR 15 with their solvent for spraying but even they don't recommend it, it makes a mess and is difficult to clean from your equipment. Definitely use a "cup gun" if you want to spray , like ones used for gelcoat. Also the fumes from spraying isocyanates are really bad for you.
All this is in their instructions that few people seem to read.
The point for the op is you will have to get all the POR 15 off before you put anything else on if you want it to last.
Old Feb 18, 2014 | 09:36 AM
chevelle600's Avatar
Car: '87 IROC-Z/28
Engine: 357 HSR
Axle/Gears: 3:73 w/Eaton Posi
I used por15 on the entire chassis of my truck when i had the cab and bed off, prepped properly and 3 coats, seems pretty durable. even used it on the push plates for my plow with no prep and there isn't even a scratch. its taken some abuse this winter too.
i used rustoleum hammertone on my rear end and my SFC's on the Z and still looks good after two years.
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
