strut mount caps
Old Feb 13, 2014 | 06:52 PM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Transmission: 700R-4
Axle/Gears: 327
strut mount caps
I just had new struts put on and now I can see the bolt do they sell universal caps to cover the stut mounts in the engine bay
Old Feb 13, 2014 | 07:02 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Re: strut mount caps
If you are near a junkyard the Firebird and Camaro ones are the same. Use a small screwdriver to pry off (they are made of thin plastic; they will bend easy)
Old Feb 13, 2014 | 07:36 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
If they were there before I would go back and make them replace or if they can find the one they took off
Old Feb 13, 2014 | 07:48 PM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
ok thanks
Old Feb 13, 2014 | 08:03 PM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
do you guys know ifthe stock caps will fit on the moroe strut mounts
Part Number To perform a search, you must enter at least one character (must be letter or number).
Your search results: 1 record(s) returned.
Image Part Number Part Description
901924 Strut-Mate Strut Mounting Kit
Part numbers with ® and ™ are registered trademarks of Tenneco and may not be used or reproduced without permission.
Old Feb 13, 2014 | 08:15 PM
Engine: LQ4 ls 6.0
Thats why they didnt put them on I thought you just replaced the struts you may need to contact Movetech and see what they have most aftermarket mounts look cool so you dont need any covers
Old Feb 13, 2014 | 08:29 PM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
ok thanks I will give a call and see what they say
Old Jun 20, 2014 | 09:22 PM
JnC92Z28's Avatar
Car: 1992 Z28
Engine: 5.7L TPI
Transmission: A/T
Axle/Gears: G92 / 3.23
Has anyone found covers that will fit the Monroe strut mounts? I just replaced a broken RH mount on our '92 RS driver with a Monroe 90-1923 only to find that the OE cap is too large to fit into the new mount. Its only cosmetic, but I'd lke to have covers.
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
redmaroz
Apr 25, 2017 07:14 AM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
