Putting a older Column in an 89. Need help
Old Mar 29, 2014 | 09:33 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
I started another thread in the wrong forum. Here is attempt #2
I have had zero luck finding a good tilt column from 89 for a 5 speed car, but I know where one is from 88. My car has VATS bypassed on the orange while on the column. Does that mean when the new column comes in I wouldn't have to anything special to make it work since it won't have the orange wire?*
Please advise
Old Apr 9, 2014 | 09:59 PM
jamesclark's Avatar
Car: 1983 Camaro Z28,1995 camaro
Engine: GM performance parts 350, 300 HP
Transmission: 700 R 4
Axle/Gears: 3:73 gear ratio
Re: Putting a older Column in an 89. Need help
im also having column issues with my 83z. finally found a place where i can get a column, but after a failed attempt at rebuilding mine, i filed it. the place where i can get the new one is asking if i have int. wipers and cruise. im not sure now since my old column is now in some garbage heap? any ideas?
Old Apr 9, 2014 | 10:47 PM
Mad Myche's Avatar
Car: 89 Camaro RS
Engine: 2.8 V6
Transmission: Automatic
58marc- That wiring connects into the ECM, swapping out the column does not altar the need to bypass.
jamesclark- look under the hood for the cruise control crap. Or decode the options list located inside the center console
Old Apr 9, 2014 | 10:50 PM
58mark's Avatar
yeah, I bypassed the VATS. car runs fine, but I may have to remove the column anyway because of the wipers on the 84 (it's actual age) column don't seem compatible with the 89
Old Apr 13, 2014 | 08:54 PM
jamesclark's Avatar
thanks. someone told me that i could put a column in with int. wipers , that the pin connector is the same and would work even if my z had standard wipers. is that true?
Old Apr 13, 2014 | 09:00 PM
58mark's Avatar
I couldn't get mine to work at all. I ended up putting the original column back in
Street Lethal
Apr 30, 2019 12:14 PM
Out-Cast
Mar 22, 2019 09:39 PM
Out-Cast
Aug 23, 2015 06:33 AM
Pemberton76
Aug 15, 2015 07:15 PM
