need help and info please
hello guys today I took my Camaro out for a quick boot and when I hit 60k my front end started to shake like crazy and my my steering wheel too. what could be causing this? thanks for any info.
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
Re: need help and info please
things to check (not in any particular order)
Tires, broken belts or out of balance. IIRC you have a18's. make sure the beads are seated properly all the way around the wheel. Very unlikely a tire shop would let them go like that but worse things have happened. Make sure your wheels aren't bent.
wheel bearings, push back and forth on top of tire.
Steering linkage, put the front of the car up on ramps and have someone turn the steering wheel back and forth slightly while you get under the front and see if the linkage moves solid of if there is any slop.
Good luck.
Good luck.
3rdgenparts
May 21, 2016 11:50 PM
Linson
Oct 1, 2015 09:50 PM
