New Design for Mini Ladder Bars
Old Apr 16, 2014 | 06:26 PM
12cjsuko's Avatar
So, ive been doing a lot of researching lately, and have come to the solution of modifying an 8.8 mustang rearend for the drivetrain. I rally don't want to weld a torque arm mount on to the pumpkin.... sooo, ive been researching the mini ladder bar option. and from what I understand, is that using pete z bars hook great, but cause anti-squat, and can cause binding in a street ride. from what ive seen, people are using stock lca's with bushings. my thought is to eliminate the bushings, with heim joints. therefore eliminating the binding when the rearend articulates. im just looking for a little helpful criticism on my design. I found a good after market company that makes very strong lca's and panhard bars. Massive racing products? heres the idea im heading for.
Old Apr 16, 2014 | 06:33 PM
12cjsuko's Avatar
Re: New Design for Mini Ladder Bars
here is the company that sells the lower control arm that I plan on using. from there I will make a channel that is cut for the exact width of the tubular arm. the tube will fit snuggly inside the channel, and then welded in tight
http://massivespeedsystem.com/_massi.../i-341854.aspx
Old Apr 17, 2014 | 12:33 PM
12cjsuko's Avatar
Sorry if the picture link wasn't working
Old Apr 17, 2014 | 06:19 PM
I see 2 problems:
  1. They're not "ladder bars" anymore, which do their job PRECISELY BY binding up the rear as it tries to articulate in ANY direction other than straight up and down, and thereby keep the car pointed in a straight line; and
  2. The instant center needs attention: calculate where it is and tell us what you think. As in, you think you get too much anti-squat with whatever else, you probably won't like what you get with that.
Other than that, ...
I shouldn't call them "problems" though. How about, "opportunities for further research".
Old Apr 17, 2014 | 06:25 PM
12cjsuko's Avatar
so, I would be better off using a bushing style lca, that way the axle wont articulate on takeoffs? I'm just trying to think of a way to make street driving a little more tolerable. its the same exact idea as the pete z bar setup, but allow a little more articulation on the street. and yes, I know the instant center is pretty bad, but I like the way it puts the force the pavement
Z28/ZR1
Oct 23, 2015 01:04 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
