Hotchkis and strut issues
Old May 1, 2014 | 09:54 AM
HybridZ's Avatar
Car: 13' ZL1/91' Z28/10' Audi A5
Engine: 6.2L SC/5.7L 350/2.0L Turbo Quattro
Transmission: M6/700R4
Hey guys, I have the Hotchkis springs on my car with Bilstein struts. After a little while I started getting a knocking noise from the front every time I hit a bump or even on slight bumps and uneven roads. Turns out it was my strut mount brackets that went bad. Got them replaced and no more knocking. After about a few thousand miles the knocking came back. Same issue. Mechanic said the strut mounts are being damaged because of the drop. Anyone have this issue or know of anything else that may be causing it. Thanks in advance.
Old May 2, 2014 | 07:05 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Hotchkis and strut issues
Get a set of aftermarket camber plates. They are raised higher than stock and use bearing instead of the rubber donuts. Umi performance, founders spphn and a few others make version s of this part.
Old May 5, 2014 | 03:57 PM
HybridZ's Avatar
Hhhmm ok thanks for the info. I'll look into this more.
db057
Apr 28, 2019 07:45 AM
J-money
Jan 4, 2019 09:45 AM
TheTraut88
Sep 11, 2015 05:16 AM
383cam
Sep 9, 2015 06:01 AM
SG91camaro
Sep 5, 2015 10:27 PM
