could i put v8 struts, springs, and suspension in general on a v6 82 camaro?
Car: Acura Integra, Mitsubishi Eclipse
Engine: b18b1 bored out to 2.0
Transmission: Manual
I am thinking of purchasing a 82 camaro v6 with a v8 tpi engine swap but a major deciding factor for me is the aftermarket. Can I put suspension pieces from v8's on this v6 chassis to stiffen my ride and give me a better hooning experience?
I am just unsure if they have the same holes to bolt everything up. For instance I would like to get sway bars, springs and struts, bushings and subframe reinforcements but I am unsure this could be done with a v6 chassis.
I know the aftermarket for v6 is slim pickens and I know this is a noob question so please don't flame me to hard!
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: could i put v8 struts, springs, and suspension in general on a v6 82 camaro?
Chassis is the same. Everything will swap over.
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
Car: 1998 Camaro Z28
Engine: 6.0L
About the only difference is the front springs. There may be a slight difference in rating on the rears, not sure, but you can definitely run V6 rear springs w/ a V8.
Side note, as a previous V6 owner, the aftermarket isnt as abundant as a SBC, but if you search for a while on the V6 board and read the stickies, there's a decent amount of mods you can do, if you're interested to. I modded mine for about a decade and it was fun to play with.
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
I'm running all V8 suspension pieces on my camaro that originally came with a V6. Only difference really is the spring rates on the front springs. As mentioned above, you can run V6 rear springs with a V8. I did for a year or so till I found some rear V8 springs.
Thank you all very much for the information.
I am looking into the wonderbar so thank you for informing me of this.
I'm going to meet a guy tomorrow to take a look at his '82 v6 that he put an '86 vette TPI engine in with a 5speed. So the fact that I can stiffen this chassis and upgrade the suspension from
more common 3rd gens is HUGE in the decision making process. If the car is in good condition and I buy it ill post some pics and get some ideas from more seasoned 3rd gen owners on how to improve the car with what I want to get out of it.
I recommend you have a wonder bar in that list too.
