Roll Cage
Old May 20, 2014 | 11:04 AM
DirtySpleen's Avatar
Car: 1991 Camaro RS
Engine: 5.0 L03
Axle/Gears: 3.43 Torsen 10 bolt
Roll Cage
I routinely autocross and drift race my 91 camaro, and some events require a cage. My question is whether sub frame connectors would be of any use with a 6 point cage welded in. I want SFCs, but if a cage is going to render them pointless, ill just skip them and go for the cage. Thanks!
Old May 20, 2014 | 12:43 PM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
Re: Roll Cage
A well done cage will be orders of magnitude stiffer than subframe connectors. When you say 6-point I assume just a single diagonal door bars and 2 down bars in back? If I were building something for a class that just required a roll bar I'd do a 10-point. Using door X-bars that are tied into the front and rear shock mounts. It should make for a very stiff and light cage. The SFC's at that point are probably just extra weight.
If you just want a simple rollbar, the SFC's should still help.
Old May 20, 2014 | 04:22 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: Roll Cage
SFC with a 6 point will do more then just a 6 point by it's self.
i can tell you the 2 together. work fantastic. and you can always add more bars if you need them....
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
FueledSoul
Sep 30, 2015 09:18 PM
FormulaEngland
Sep 30, 2015 01:50 PM
tmork454
Sep 29, 2015 06:33 PM
