Loose steering shaft can this join be rebuilt?
Old Jun 2, 2014 | 05:51 PM
Green89IROC305's Avatar
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
I have included this image to help identify the loose joint.
I want to rebuild this shaft if possible, otherwise I could try the jeep swap I have heard of. The joint allows some rotational and up and down motion. I am not sure how tight it is supposed to be, but I suspect I should not be able to cause it to lift at all or rotate by hand.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
GeneralIesrussi
Sep 3, 2015 03:23 AM
tonys91rs
Sep 2, 2015 07:07 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
