DIY panhard
Old Jul 22, 2014 | 11:33 AM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
DIY panhard
My panhard is tweaked on the left end, someone trying to tow the car from being stuck, probably.
I know there are aftermarket tubular adjustables available, with choice of rod ends: Heim joints or poly-bushed.
I'm going to leave the right end alone for now, do a spherical rod end on the left, box the thing, then worry about a poly bushing later.
This is mostly a test if it can be done by just anyone, and if it can be affordable. Pics tomorrow.
cosmick's Avatar
Re: DIY adjustable panhard
I goofed on the thread title.
Old Jul 23, 2014 | 09:39 AM
cosmick's Avatar
Re: DIY panhard
Old Jul 23, 2014 | 09:40 AM
cosmick's Avatar
Re: DIY panhard
Not boxed yet, but still under $20.
Old Jul 23, 2014 | 09:56 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: DIY panhard
Thought of doing exactly that but still learning to weld so wouldn't trust my work. Where did you get the adjustable end?
Old Jul 23, 2014 | 10:17 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: DIY panhard
Looks like a tractor supply top link
Old Jul 24, 2014 | 08:45 AM
cosmick's Avatar
Re: DIY panhard
Exactly. No concern about strength, but it needs to be sleeved to match the bolt, or drill the bracket for a larger bolt. Haven't decided yet.
Old Aug 7, 2014 | 08:57 AM
cosmick's Avatar
Re: DIY panhard
I could be mistaken, but I'm thinking I should turn this thing around. Should transfer several ounces from unsprung to sprung. Maybe not enough to make any real difference. Can't hurt to try.
Old Aug 7, 2014 | 09:31 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: DIY panhard
i boxed mine years ago with some bedframe angle that i found in the trash. i just stitch welded it here and there cause i didnt want to warp it too bad. i like your idea with the rod end.
Old Aug 8, 2014 | 09:20 AM
cosmick's Avatar
Re: DIY panhard
Thanks!
I'm thinking a little boxing of the cross brace right above it can't hurt, shouldn't add more than a pound.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
meeklay812
Oct 1, 2015 03:46 PM
TOMcat GTA
Sep 15, 2015 09:31 AM
