Anybody run a pinto rack on the street?
Car: 92 camaro
Engine: 409 sbc
Transmission: TH 350
Axle/Gears: 4.10, mini spool, camaro housing
I'm doing an LS1 swap with a tubular k-member and was thinking about going with a pinto rack. Just wondering if anyone runs one of these racks on the street? Any likes or dislikes? I have found limited choices so far with LS1 swap k-members with a pinto rack as an option.
Re: Anybody run a pinto rack on the street?
Well ALOT of Pintos used to run those...
Ask any Pinto owner.
Maybe there's a message hidden in there somewhere?
Most R&P steering doesn't move the steering linkage ANYWHERE NEAR as far as the worm & sector system. They tend to need spindles with MUCH shorter steering arms. Therefore changing over to that is more involved than just bolting it to the K-member.
The Pinto steering setups for race cars are just that; for race cars. Specifically for ones that only go STRAIGHT and only need to turn a small amount to keep from hitting the wall. This is one of those things where just because "all the fast cars at the track have it", doesn't make it A Good Idea for every street car.
Car: 92 camaro
Engine: 409 sbc
By limited choices. I ment with LS motor mounts. If I was running a sbc. There would be more choices. Also I forgot to mention that my car would be lucky to see 1000 street miles a year. It's just a toy to cruise a little bit and take to the drag strip.
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
I run a pinto rack on the street, I have had absolutely no problems with the setup
Car: 92 camaro
Engine: 409 sbc
That's a nice setup you have there. I wanted to run the racecraft k member but it's not available with LS motor mounts for whatever reason.
Most people response that I have read on here is that is tough, but I can't say that, it is not power steering, but it is no harder than all the manual steer cars that I have ever owned.
I know when I first changed over I had bought a grant steering wheel which was smaller that the factory steering wheel, at this point it was hard turning.
I bought a new steering wheel that was about factory size and that made all the difference
Terrell351
Jun 13, 2021 01:13 PM
Street Lethal
Aug 13, 2015 08:28 PM
