Where to place jack stands? (87 iroc-z28)
Old Aug 26, 2014 | 08:50 AM
xXasylumXx's Avatar
Car: 87' Iroc-z28
Engine: 350 TPI (L98)
Transmission: T-5 Non W/C
I want to start by saying sorry If this is in the wrong place.
Im new to fixing up cars and I wanted to fix the 87 iroc-z28 in my garage. all it needs is new spark plugs and wires. but I would have to get under the engine. I have zero idea as of where to place the jack stands. I know how to jack the car up thanks to my Haynes manual. but I have zero idea of where to place the jack stands in order for me to access the bottom of the engine.
it would be a real help if someone could tell me where to put the jack stands and show me pictues.
Old Aug 26, 2014 | 08:58 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: Where to place jack stands? (87 iroc-z28)
Just wondering- why do you need to get under it to remove the spark plugs and wires?
check out this thread, it has pics and stuff to help.
https://www.thirdgen.org/forums/tech...ng-points.html
Old Aug 26, 2014 | 10:06 AM
gt4373's Avatar
Transmission: 5-Speed Manual
Some Plugs Are Easier To Get At From Under The Car,Especially The Driver's Side With The Steel Brake Lines And Emission Air Pipes In The Way.
Old Aug 26, 2014 | 11:17 AM
Car: 1983 Z28
Interesting, good info to know. Having never had the stock engine I had no clue.
Old Aug 29, 2014 | 08:46 PM
xXasylumXx's Avatar
Car: 87' Iroc-z28
you are very correct. the thread explained everything, this is no longer an issue.
Old Sep 13, 2014 | 06:25 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
While it may be hard to get the last two plugs out on both sides I was able to get them from up top, you just really need to cram your arm in there, you can put jack stands on the subframe and rear end on the axle tubes. when putting a stand on the back left sub frame be EXTREMELY careful that you don't have the stand touching the brake and fuel lines. I learned this the hard way.
Old Sep 13, 2014 | 07:36 PM
xXasylumXx's Avatar
Car: 87' Iroc-z28
as i jacked the car up i saw that and i almost put it on there, and yeah i had to get my arms deep in the car, in the end all i have left is to replace the oil filter, gas and oil in the car
Old Sep 13, 2014 | 09:02 PM
TylerSteez's Avatar
Engine: 383 stroker
Nice, Might as well do cap, rotor, and fuel filter while you're at it.
Linson
Oct 24, 2025 02:00 PM
ZEEYAA
Apr 16, 2023 08:29 PM
Pac J
May 17, 2020 10:44 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
tattmann
Sep 27, 2015 05:20 PM
