Longer Wheel Studs For The Front.(bolt on)
Old Sep 12, 2014 | 11:07 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
I Forget who was asking..
but this is what i found for a Direct bolt in.
1" longer plug and play
done..yes the rotor is on the wrong side....pics only
Old Sep 16, 2014 | 07:34 AM
Billy LaRue Jr.'s Avatar
Car: 87 Trans Am
Engine: Chevy 350 ci, Vortec heads
Transmission: GM 350
Axle/Gears: 3.73 Posi
Re: Longer Wheel Studs For The Front.(bolt on)
Will those studs work on the rear if it has disc brakes ?
Old Sep 16, 2014 | 09:59 AM
I forget if thay are the same size studs front and back...ya can go to any parts shop/site. And punch It in/ask.and see if the same part number for stock fits front and back.... put my 9" in back when my car was just a few years old...if the stock studs are the same front and back then yes they will fit..
my 9" rear came with screw in 1/2 studs made by strange eng.
Old Sep 16, 2014 | 04:51 PM
SlickTrackGod's Avatar
On Probation
Yes, same front and rear. I used ARP 1/2"-20X2.970" .568 knurl press in studs. I simply freehand driled the holes to .562" and then pylled them through with lugnut and washers on the front side to seat the knurl. It is very easy to do and pretty much self aligning since oem holes exist as pilot guides.
Old Dec 24, 2021 | 01:30 PM
Ponch85rs's Avatar
Car: 1987 Chevrolet Camaro Sport Coupe
Axle/Gears: 3:42
do the factory lug nuts fit these new studs? Im in the middle of the conversion, and after measuring its gonna be real close with the 2 1/2" studs.
Old Jan 6, 2022 | 08:30 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
They will if the tread is the same, although you may want pass through acorn style nuts if you are not sure how much stud you will have sticking out of the rim. The thread should be M12 by 1.5 if I remember correctly.
blacksunshine'91
Aftermarket Product Review
Oct 20, 2014 01:00 PM
89 Iroc Z
Aug 26, 2003 07:24 PM
Timz2882
Jul 18, 2003 08:37 PM
RU-QWIK
Mar 21, 2003 04:48 PM
Glen
Oct 11, 2002 09:54 PM
