replaced springs; now rear sits to high. fixable?
Old Sep 14, 2014 | 09:13 PM
91 zeee's Avatar
Car: 1991 Z-28
Engine: 383 TPI
I just replaced my springs with MOOG oem replacement springs (1991 Z28). Now the rear sits about 1.5" too high. Looks stupid. I really don't want to lower the car. Is it possible to somehow lower the rear to get an even ride height? (local spring/suspension shop said there was nothing they could do and that cutting the spring was not an option).
Is there a way to keep these springs and fix this?
Old Sep 14, 2014 | 10:25 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: replaced springs; now rear sits to high. fixable?
Cut the springs with a cutoff wheel. Take out 1/2 a coil at a time until you get the ride height you want.
Old Sep 15, 2014 | 06:58 AM
Better option would be, replace the equally sagging, collapsed, wore-out fronts, to restore the original ride height at both ends of the car.
Here's what the car is SUPPOSED to look like; IOW, what they looked like brand-new.
Clearly, most of these cars today, need springs pretty bad.
Old Sep 15, 2014 | 05:39 PM
91 zeee's Avatar
Car: 1991 Z-28
Engine: 383 TPI
sofakingdom... I agree. and those pics are cool. I am going for the factory ride height.
Alky....are you sure I can cut them? I have seen on here where people have done it; some say don't. But it concerned me when our local suspension shop said they could not cut them..... any idea what the problem could be with cutting them? I like the idea and it makes sense...I just wanna know why some say it cannot be done correctly.
Old Sep 15, 2014 | 06:45 PM
AlkyIROC's Avatar
Car: 87 IROC L98
All springs can be cut to achieve the desired ride height if too high. You need to cut small pieces off. 1/4 to 1/2 a coil at a time can make a big difference in the ride height.
You need to cut them with a cutoff wheel. Cutting them with a torch is a big no-no. The heat from the torch will change the temper.
Old Sep 18, 2014 | 08:38 PM
91 zeee's Avatar
Car: 1991 Z-28
Engine: 383 TPI
ok, I'm gonna do it. Thanks for the help!
Old Sep 19, 2014 | 08:37 AM
nater's Avatar
Car: 1984 camaro berlinetta
Engine: v8
the car will set different for awhile expecialy if you only changed the rear. the springs need time to settle in. i combined the old springs from my car with some i found in my grandpa's garage. the car set funky for a couple of weeks and looked kinda stupid but it eventuly settled in and looks/rides just fine. you might just have to wait
Old Sep 22, 2014 | 07:42 PM
91 zeee's Avatar
Car: 1991 Z-28
Engine: 383 TPI
cool. thanks
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Aug 26, 2015 03:32 PM
TheExaminer
Aug 25, 2015 07:34 PM
